The year isn’t showing proper.
Upload description: sameasiteverwas
The year should be 1983, not 1992.
Upload the file and I’ll show you the actual tags of the files not the limited view that whatever you use shows.
I sent them twice, did it work?
No you did not upload that media file…
Sorry, did you mean the .flac music files? Or the logs— cause I did upload that.
I mean the actual file else how could I show you it’s content?
Just wanted to make sure— here’s one; for some reason I can’t send a .flac so I put it on a Google Drive. 12 - We Bite.flac - Google Drive
The reason is that you did not use the link I gave above ![]()
Anyway here’s your actual tags:
The RELEASE DATE tag being a full date and more precise than the DATE that only have a year it’s used as it’s the proper one with the best date.
And the date is then 1992 as expected. Fix the tags to have the year you want.
I did use the link for the logs; I uploaded it twice, but whatever.
I used automatag and mp3tagger, so what program are you using to fix it?
Any app that shows all the tags, like mp3Tag or kid3, music brainz picard, …
