Would you consider a graphic refresh of the Symfonium widgets?
Add as much details as possible.
Not a functional change, but perhaps would give the widgets a better look?
Just give some more polish to an incredible app!
Just make the widget(s)more visually appealing
I’ll attach screenshots from PlayerPro, PowerAmp, Rocket Player, and GoneMad
I’ve labeled them for you to see.
I personally like PlayerPro and Rocket Player best of all.
Thanks for your consideration
