Widget stops showing cover art and player buttons
So no from the logs, the app is restarted by something for unknown reason, then killed before finishing to reload the queue.
Then when the app is manually started the queue load normally and the widget have proper data.
Will see if I can find why it’s killed and workaround if possible.
Ok, I may have discovered , at least in my case, the possible why…
I was looking through some other log files for foldersync, and it appears I had some music file changes that triggered a symfonium music DB update at the time I sent you that symfonium log.
Is it possible that as it refreshed the music library, even though the queue is still active ,(though not playing), it would require that queue to actually start again to get the widget refreshed?
