When skipping to a next song, the song being skipped stutters for a bit
When skipping to a song that is currently playing, there’s often a bug where the song that is being skipped, turns off and then turns back on for 0.2 sec or something, before the next song starts playing.
I uploaded a log.
Interestingly, I tried to screen record the issue so you can hear it, but I can’t hear the bug in the video.
Also, this issue happens both on my phone speaker and my bluetooth speaker.
Here is a video where you should be able to hear it easily: https://streamable.com/js7ccp
I wonder if it’s an issue with cache or something?
Keywords: play next, transition, skip, skipping
Upload description: Skipping songs during the log/debug process, I could hear the issue a few times
This is a bug on some devices with their EQ libraries.
Disable Symfonium EQ and System EQ and you should no more hear that.
I still have not found a workaround as I can’t reproduce so not much I can do.
Thank you. Indeed, it’s Symfonium 's EQ that’s messing things up. The system one doesn’t seem to affect the issue. I can tell transitions are smoother without Symfonium’s EQ.
Even turning off all effects individually but leaving “processing engine” on, the issue persists.
I can’t give you more info I think… Maybe it happens more when the song being skipped is being loaded?
As I said this is a device bug, the device EQ libraries does that not Symfonium and for the moment I have no workaround.
