What are these double(sort of) entry in albums
Usually album only have the tracks(red line)
But In some albums, (like the attached), there’s complementary double like this. Which is redundant at best.
Is there any use of that? Why it appears only for some albums. How do i disable this.
Fix your tags ? It’s the work tags. Or disable their usage in the album page settings.
i tagged my media through musicbrainz picard. no idea what this feature is for but thanks, found the setting to disable it.
