Weird PEQ behaviour
So I know this feature just released and its in beta and im very grateful for it but i think it may be an easy fix. So the problem is that when i launch the app the peq is applied from start with no problem but the when i play some songs on the third or fourth one the pre-gain stops applying, i have to ho into the settings and change or add a filter / change the gain to restore the pre-gain setting
Upload description: tratin-peq
have peq with pregain, skip 3 songs, error detected
I don’t see any configuration change in the logs.
Ok was able to reproduce, needs some sample rate change or other cases resetting.
Wow that was a quick reply! Its weird that you didnt see the config change in the log because i did add a new filter. Also in my case no sample rate was changed, i tried with a downloaded album all with the same sample rate & bit depth (44.1 / 16 flac). thank you so much for this awesome app btw :heart:
