Wear OS: Choose Phone as Playback Device
A user, with the Wear OS app, should be able to choose their paired phone as a playback device. The playback would be carried out by the phone, not by the watch. During playback, the watch would be able to carry out any media controls in the same fashion as the Wear OS app during watch/phoneless playback.
Being able to better control media playback with your watch, without needing to play music on the watch. I already extensively use the Wear OS Media Controls app to control playback on my phone for playlists I have initiated on my phone, but ideally I should also be able to search my library and initiate phone playback from my watch as well.
Wear OS watches are generally better remotes than playback devices. Long-running tasks on a watch like audio playback via bluetooth will drain the already quite mediocre battery on Wear OS devices. Off-loading playback onto the phone gives you the convenience of the watch interface, without the drawbacks of watch audio playback. Also, in certain situations, people don’t want to take their phones out unless absolutely necessary, so being able to initiate phone playback via Wear OS would give them the ability to play music on their phone (presumably via bluetooth headphones) without having to take their phone out. The current generation of smartwatches shine when a user can seamlessly interact with their phone without needing to take it out of their pocket.
I am a software engineer so I totally understand how this might be easier said than done – especially where I’m quite ignorant of how Watch/Phone interactions are mediated. But I do think this is the kind of use case that best plays to the strengths of the current capabilities of Wear OS smartwatches with a limited amount of battery life.
The Spotify Wear OS app allows you to choose “Your Phone” as a playback device when playing music. This approach meets all this use case’s requirements.
Yes, much needed feature. Only spotify support this feature but spotify doesn’t support high res audio tracks. So, could you please implement this feature?
I’ll go further and say this is literally the ONLY feature I’m looking for in a media player. My watch lasts all of 3 hours while playing music, so playing from it is basically a non-starter. And if I need to pull out my phone to pick music, I might as well just stick to plexamp.
I would happily pay for a lifetime subscription, but honestly without this symfonium is useless to me.
Bumping this because I would also still like this feature to be implemented if possible :heart:
