Volume Decrease Bug
Beta
Volume automatically goes to 40 when manually switching tracks (next/previous etc)
Or 60 if you disable DAC media button option
Also inline headphone buttons don’t work consistently.
Subsonic (Open)
1- Use USB Exclusive mode
2- Enable DAC Button option
3- Switch Track
kage125
can you clarify this ?
Yes
The Buttons on my IEM (Volume Up and Down) they seem to work when app is open but when I lock the phone they stop working to increase or decrease the volume
Also even my phone volume buttons don’t work unless I open the app and press them
Same happens with Pause and Play button on the IEM esp when device is locked.
Even notification pause and play sometimes don’t work and have to open the app to Pause.
All of these issues exist iff one uses USB Exclusive
Else everything is fine for normal users
Can you upload a new log showing just that ?
2 logs:
  1. Exclusive + DAC button enabled, the buttons when screen on working, then screen off not working.
  2. Same but without DAC button enabled.
Was able to reproduce volume auto decrease in pause and play
Also button not working when phone is locked
But volume now working but not able to pause using iem button and also phone notification
New log named kage125
@Tolriq Any update regarding this.
All things can be managed but volume is still dropping to 30 on every change of song be it automatic or manual next.
Thank You
Try beta 3 and report back.
First impressions seems like all the volume issues have been fixed.
Edit : The button issues still persits (volume buttons don’t change symfonium volume in usb exclusive mode) Also pause and play buttons don’t function sometimes, have to force stop and clear cache then sometime works sometime doesn’t.
But came across a new bug
Play Something
Pause media
Remove USB
Media starts playing automatically again over phone speakers.
Uploaded logs by the name of kage125
I uploaded logs with Koukunpoika tag. I updated yesterday to beta 3 and noticed the same volume drop bug. It only happens when manually changing to other tracks and always drops to 20 no matter what I had it set to.
You are not in beta 3 …
Oh sorry, thought I updated from beta 2 to 3. However now it’s updated and the same problem continues. Uploaded new logs with Koukunpoika tag.
