Visual Bug: Smart Filter rules
The value of Smart Filter text-entry fields is not hidden when changing to a Boolean filter.
This is visual only and has no impact on the results of the filter.
Upload description: Celorien_RuleNum
Sorry to nitpick, just a little thing that probably slipped under the radar.
Open Smart Filter menu (I tested only Playlist and All Albums). Select an option like “Last Played - Within” enter a value in the field, and Save.
Tap the condition you just saved, and change the type to “is Missing” and Save.
The value you entered still shows.
