Version 6.0.0
Notes:
Testing and reporting issues for the new providers is important since, when they are stable, they will open support for other providers like Google Drive, One Drive, … -
Added:
Add support for Samba (SMB v2/v3) shares as media provider. (Experimental feature, please report issues with details to handle all the different servers out there)
Add support for WebDAV as media provider. (Experimental feature, please report issues with details to handle all the different servers out there)
Big OpenSubsonic initiative progress and new features (Servers needs to implement them see forum. LMS support nearly everything and Gonic support multiple album artists & genres)
- Multiple artists, multiple genres, composers, mood, record label, song bpm, song comments, ...Many new data bringing up to date OpenSubsonic servers on pair with more modern alternatives.
- Seek during transcoding (LMS and Gonic).
You can now import M3U/PLS playlists in file mode from Local device in SAF mode, Samba and WebDAV providers. (3 dots menu then import. Beta status: only relative paths are supported for now, please report your different playlist formats to add support for them)
Add option to auto scan media at app start for local provider in SAF mode. -
Changed:
Sleep timer now remember the last used value.
Multiple music folders in Subsonic servers supporting them are now seen a multiple libraries for easy filtering.
When sorting albums by display artist also sort by album name. Introduce a new sort by display artist then year.
Updated AutoEQ database. (Go to Settings/Advanced/Reset AutoEQ database to update)
When clicking an m3u or pls playlist in file mode on supported media providers, the playlist is now resolved and it’s content played. -
Fixed:
Fix broken playlist import for Kodi provider.
Fix automatic offline cache library selection not persisted when editing providers.
Fix possible failed test when adding a Subsonic host with proxy auth.
Fix some media not playing anymore due to too small buffers.
Symfonium now check the max supported sample rate by the device and transcode non supported files when needed.
Fix some edges cases of color extraction for now playing.
Fix support of TDRL tag.
Fix Plex sometimes transcoding wav files when unneeded.
Fix continuous playback option not working when Circular queue navigation option is enabled.
