Verify built-in transcoding is processing at the right level
(Navidrome)
Trying out Symfonium and loving it very much. One of the things I wanted to verify is when I am on mobile, that the tanscoding is doing this at the proper bitrate. I went to “Settings > Playback > Decoding and transcoding > Mobile maximum bitrate = 64 kbps”
When I go off of WiFi, I then attempt to play a song. While its playing I check its details, it shows as 320 Kbps.
Is it not transcoding?
Upload description: jchristl2202
You need to check the now playing screen, the 3 dots details shows the original files details.
In the logs the 64k is properly used.
PS: Your navidrome version seems outdated.
Thanks. I just noticed that myself; so I updated navidrome. I also went to the output logs in navidrome and when I am on wifi it displays as follows :
bitRate=0 cached=false format=raw originalBitRate=320 originalFormat=mp3
When i am on mobile it changed to this :
bitRate=64 cached=false format=opus originalBitRate=320 originalFormat=mp3
bitRate=64 cached=true format=opus originalBitRate=320 originalFormat=mp3
So i do believe I got it configured correctly, Thank you
