Using Metadata with Jellyfin/Symfonium
Hi,
I currently use jellyfin with Symfonium and want to make use of the Language/Countries sections in Symfonium. Does anyone know how i need to figure jellyfin or my metadata to save the Song Language and Country so it can be interpreted in Symfonium?
I think they are not supported by Jellyfin so no solution.
Ok, thanks for the fast reply!
Then i am catched between Palindrome (because of Metadata) and jellyfin (because of AudioMuse-AI-Plugin)
Hopefully the AudioMuse-AI Integration for open-subsonic gets accepted!
So i fixed at least the jellyfin part (kind off) by using the jellyfin-musictags-plugin to get the metadata into jellyfin. The problem is, the plugin saves it into jellyfin as Tag:”language:eng”. at least Smart playlist does work with that, but i think i have to do some work to make the Libary stuff working
@Tolriq do you think you would add support for parsing the tags field from Jellyfin for what GitHub - jyourstone/jellyfin-musictags-plugin: A Jellyfin plugin that automatically extracts metadata from audio files - such as ID3 tags, Vorbis comments, and more - and converts them into standard Jellyfin tags. · GitHub adds?
I now have my Jellyfin setup to use these tags and was hoping it would populate the fields in Symfonium instead of only populating the tags field
I think this would be a big win for anyone on Jellyfin or other providers that do not provide enough metadata like Open SubSonic/Navidrone
