In version 12.1.0B2, when using a local device, whether the lyrics are embedded in the song tag or are external lrc files, when playing songs with a Bluetooth headset, the title displayed by the phone system is replaced by real-time lyrics. A similar situation occurs with last.fm music tracking software like Pan Scrobbler, resulting in incorrect song recognition. To rule out the possibility that it’s a system issue, I used USB Audio Player Pro to play the same song with the Bluetooth headset, and both the phone system and Pan Scrobbler could correctly read the track title. Therefore, I’m certain that this is a problem with Symfonium. Then, I tried playing the song with lyrics using a wired headset in Symfonium and found that Pan Scrobbler could read the track title correctly. I concluded that this is not a problem with the Bluetooth headset itself because other music players can have their song titles correctly recognized by Pan Scrobbler and the phone system when playing songs with lyrics. This issue only occurs when playing songs with lyrics using a Bluetooth headset in Symfonium (where the track title cannot be correctly recognized by the phone system and music tracking software). Besides I only use local devices, I don’t know if there are similar problems when using other media providers. I hope this issue can be given attention.
Upload description: SGSQX-if TWS
First, connect the Bluetooth headset, open Symfoium, and play the song containing lyrics in the local device media source. When the playing time reaches the lyrics of the first line that is not the title part, open the notification interface of the mobile phone system, and you will find that the track title displayed is replaced with the current lyrics, and it will be updated in real time. The feedback to Pan Scrobbler was similar, with the lyrics refreshed once each time the notification was viewed, because the track title was replaced with the lyrics, which prevented the song from being correctly identified for last.fm playback. The version I use is 12.1.0B2, the Bluetooth headset is OPPO Enco X3, and the system is Coloros 15 based on Android 15. At present, other conditions remain unchanged and only the music player is changed, as long as it is not Symfoium, there is no similar problem.
