Updated to Version 15 stable.
Now the device which used to work with usb exclusive even that is failing.
Now both my devices don’t work in USB Exclusive. But they work in normally otherwise.
Even tried to do a fresh install but that too didn’t work.
Subsonic (Open)
- Select USB exclusive as output.
- Try to play media
Uplaoded two new logs please look into it when you can.
The tab used to work till beta 10 update.
kage usb play samsung tab ; kage usb play phone
