Upnp playback issues
Beta
Various issues playing from either local device or SMB network share to Upnp.
I sometimes cannot play files at all, seeing popup “too many errors issues”, while sometimes a track plays, but the app UI says that the previous track is playing.
But I have pinned down one scenario: playing an album, tracks start to play then skip to next track within first minute.
SMB
Go to an album
Press play
First track plays, but after 50 seconds in the case logged, skips to next track
Second track plays for about 30 seconds, then skips to next track
Playing to the same device (a Wiim Amp) through Chromecast does seem to work, but I prefer upnp (gapless etc)
Ewan-upnp-play-issue
Your logs show Album ReplayGain is causing these tracks to be transcoded. After a playback rejection, Symfonium retries with a temporary file that is no longer available. The logs also show incomplete transcoded streams, consistent with the early stops.
Please temporarily disable ReplayGain for the WiiM output and replay the same album. If it still skips or shows the wrong track, upload a fresh log from that test.
I think I have turned off the correct setting (“Casting replay gain processor (Experimental)”?) , and it has made it through the first track without skipping, so looks like this has fixed it, thanks.
I will test more tomorrow, upload a fresh log igf the issue recurs/persists
