Upnp no waveform gets rendered
I have one problem and a request (I can create a feature request if it is out of scope).
  1. If i casting via upnp the waveforms don’t get rendered.
  2. If i cast via upnp the progress bar isn’t smooth. I think that this happens because symfonium gets the progress every second and “jumps” one second forward.
Upload description: gamebeaker_upnp_wave
1 will be fixed 2 is normal and currently no short term plans to workaround that.
I also noticed the second issue. It’s a tad annoying when you look at synced lyrics while casting since the lyrics drift slightly in and out of sync because of the inconsistent time progression.
