UPnP playback migration to TV fails. It appears there’s a few issues at hand:
my Sony Bravia’s Upnp handler doesn’t work with https. Sigh.
Upnp SetAVTransportURI isn’t respecting the ‘proxy through my phone’ setting (would let me local http it to check?)
The Chromecast receiver/renderer stub also gives a blank/black screen. Dunno if that’s a regression in the symfonium receiver stub or the tv’s default Now Playing cast handler regressed (entirely likely Sony botched it).
Navidrome
Open up the cast menu
Observe my tv showing up as both UPnP and Cast-able
Do a UPNP - playback never happens, with waits of 15-20s (takes ~10s for tv to respond)
Switch to cast, immediate playback but blank screen
hecate (i uploaded like 2 or 3 debug.log files, just grab the latest one, it’s cleanest)
yeah, mb, I neglected to redo that test case on my last re-run. I just did a redo w/ proxy enabled (switched it off towards the end, should be no diff in uri?) from bed and uploaded fresh logs.
yea, the tv just being wedged on stop is due to the tv’s Upnp receiver taking obscenely long (and then failing consistently) on https - local proxying through the phone should fix that but i don’t believe the UPnP URI gets proxied through the phone, it’s always the ssl’d url?
good to know on the cast receiver, just wasn’t sure if i was seeing a tv regression or a 14.0 regression, i have no real visibility into that. god willing there will one day be a sane smart tv
(tbh i guess my solution at this point is to just find a stereo receiver that does Upnp properly anyways - sorry, this is mostly just the tv being jank)
