Hello.
While diagnosing some casting issues I noticed that some of the songs playing weren’t getting scrobbled.
I run a log through Claude to try and sort out this and another issue (which was solved going from the beta 2 of version 15 to the 15.1.0 release), and it picked up the UPnP played ratio issue.
It seems like the played ratio for all songs played in a session is being computed based on a fixed total duration, I assume based on the first song played.
I uploaded a log fragment showcasing the issue via the “secure file sharing” webpage, as the app displayed a “over 100mb” error.
The log is accompanied by a claude generated description for clarity.
Navidrome
- Connect Symfonium to a Subsonic/OpenSubsonic server (Navidrome 0.64.2 here) and enable debug logging.
- Select a UPnP/DLNA renderer as the output device (Denon AVR-X1800H here).
- Play an album or queue whose tracks have clearly different lengths, including some shorter than the first track (e.g. Ozric Tentacles – Strangeitude: 6:26, 7:32, 7:31, then 4:07).
- Let the queue play through on its own with gapless transitions, without seeking or skipping.
- After a track shorter than the reference duration has finished (here Bizarre Bazaar, 4:07), stop playback and export the log.
- Look for the
MediaStateUpdaterlines: the second value in[position-duration]stays the same for every track (374000) instead of matching each track’s real duration. - Check the server: the shorter track has no scrobble, and it has a bookmark at its last second (
createBookmark ... position=246000).
UPnP played ratio using a fixed duration.log
