When deleting a track from the queue, show a temporary toast (or some temporary clickable component) that when clicked would undo the deletion of the item and re-insert it into its position pre-deletion.
The problem of accidentally deleting a track from the queue and not being able to undo this.
Allow the user to undo an unwanted delete operation.
Other application solutions
Usually a toast with text similar to
"Removed 1 track from queue. Undo?”
And clicking only the “Undo” part of the text triggers the undo operation.
Some other possible options:
- toast position [top, bottom]
- a confirmation modal instead?
Not part of the core request but just stating for consideration.
