Unable to view lyrics offline (.lrc files)
I can’t see lyrics when offline. I save offline files in original quality.
My setup:
Symfonium: Version 13.0.0a (127458)
Android: 13 | ColorOS 13
Subsonic server: Navidrome 0.56.1 (fa2cf362) (Docker)
Upload description: lostb053
So, I first played music with internet on, it loads, everything works, I turn of internet, switch to next song, no lyrics (already loaded songs may have lyrics).
At this point, I decided to search for a file I know for sure has lyrics (10% of my music doesn’t have lyrics), no image, no lyrics.
I turn on internet, search same again, play again from this new search, everything loads up perfectly.
I need log when you offline cache a song.
Since it’s navidrome and it only recently support external lrc. I suppose you offline cached the songs before updating to the last version ?
True actually. Though I re-sync it often. So do I basically clear current cache and redownload it?
Edit: Just uploaded debug.log
Yes for the moment to cache external lyrics you need to remove then offline cache again the media.
I already uploaded the debug log for offline cache. But actually, recaching everything solved the issue. Thanks a lot.
