Unable to skip to a specific place in a song
Song keeps restarting over when I try to skip to a specific place in the song..
Not sure what is going on, but with some of my songs when I try to skip ahead in the song it starts over.
The song is a MP4 FLAC.
I’m running on my s24 ultra completely updated.
I tried both local files and streaming over my Plex.
Any help would be greatly appreciated.
Upload description: Song keeps restarting over when I try to skip to a specific place in the song..
When I play a song and try to use the scrub bar it jumps back to the beginning of the song
Plex
Thanks, this is a bug in ExoPlayer will report to them.
Where did you get this song from? Did you reencode it via some tools or something special ?
Yes, it’s used with tidal.
Seems they have an option to extract from mp4 to actual flac files, you may want to try that.
Since it’s a piracy tool if the files are indeed slightly not conform I doubt they will want to spend time on that :frowning:
Yeah lol, I’ll try to do that. it sucks, it a bug but they won’t touch it because of that.
