UI rendering behind Android buttons in some menus
In some menus, the Symfonium UI is displayed behind the standard Android buttons (Back, menu, etc.). When trying to press Symfonium buttons in that case, then the Android buttons get triggered, making it impossible to use the Symfonium buttons.
Upload description: ui rendered behind buttons
Samsung Galaxy S8
One example where it happens:
  1. Library
  2. Title
  3. Filter Settings
Then the button “Add rule” cannot be pressed because it is behind the Android “back” button.
I added two screenshots: one show when rendering is fine and one shows the problem.
Duplicate, Compose bug on Android 9/10 will be workaround in next release.
Ok great, thanks! Sorry, I searched for it but didn’t find it.
