Treat mobile data as a wifi connection
In the same manner that you can already treat metered connections or VPN connections as mobile data connections, I would like to treat mobile data as if it was a wifi connection.
The mobile data mode implements a few “helpful” data saving strategies, like skipping extracting waveforms, etc, stuff like that. I don’t care about my mobile data usage at all.
I don’t care about my mobile data usage and would prefer all features always be enabled over cellular data. I don’t have a data cap, so.
Or make the waveform extraction configurable but I’d rather disable any other restrictions as well.
There’s no need for that you can enable waveform on all connections and every single possible mobile only setting is configurable.
Oh. Sorry, I tried to find the setting and I looked here in the forum for someone talking about it and I couldn’t find it. Where in the menus is this?
Oh I found it, for anyone looking it’s in advanced > database.
