Transparency Slider for NPS Cover Icons
Low priority request, but would be great if you have time to add it in.
Currently the Cover art’s four-corner icons only allow selecting Low/Normal/“When Paused” for the Icon Overlay, which are all different levels of transparency.
I would like a slider for precise control of the transparency. (The Cover strings allow exact values for both normal overlay and “when playing” overlay.)
Limited control over level of transparency for Cover Icons
  • Set desired transparency levels of Cover Icons
  • Ability to exactly match other elements
Pic 1: the Top-Right button is a Cover Icon set to “Normal” overlay. Notice it is lighter than the bottom two buttons (which are string icons).
Setting the Cover Icon to “when paused” makes the overlay dark enough to match, but of course it is not shown when playing.
(Transparency for elements was set to balance the Top/Bottom bars, which ironically means they are not the same color.)
