Transition Maestro: Memorize the value of Max tracks of insert
Memorizes the last value of the maximum number of insert tracks for the Transition Maestro.
or apply the settings only when closing the Smart Queue/Smart Flow window.
or add an Apply button.
The issue I encountered while using Smart Flow’s Transition Maestro is that the default maximum tracks to insert is set to 12, and when the option is pressed, it immediately inserts the tracks into the queue. This may result in the first song having more insert tracks than anticipated.
Enables more precise control over the number of Smart Flow results.
Media Provider: Jellyfin (with audioMuse-AI)
Symfonium version: 13.3.0a (127536)
You mean like the Playback/Advanced settings Default max number of smart flow tracks ?
Oh, sorry, I didn’t notice that the advanced settings could adjust the default values.
Thank you for your help.
