When I play a single song, I can select the “Tracks [Sonic analysis based]” mode using the “Smart flow / Smart queue” option and then select “Transition maestro.” Now I would like to use this function in a playlist as well, because it allows me to limit the genres that are to be mixed (as much as I love the “Transition maestro,” it is not yet very good at automatically recognizing which track belongs to which genre and can be mixed without any problems).
In the “Playlists” menu item, I can select the icon with the glass and the note. This creates a “personal mix.” However, I cannot specify which “Smart flow” algorithm should be used for this. I would prefer to use “Transition maestro.”
Is there a solution?
