Up until the past few updates of Symfonium Ive had working transcoding through Jellyfin. Transcoding no longer works and will default to original quality playback or not play at all while on cellular with a max bitrate set. Even with Symfoniums Transcoding engine turned on the issue remained the same. I use VAAPI on the Jellyfin backend for transcoding and verified that Jellyfin does have working transcoding by playing a video at a lower quality, which worked without issue.
Symfonium Settings:
Cellular Maximum Bitrate: 256 kbps
Force Instant Transcoding: On
Transcoding engine: Off
debug.log (794.8 KB)
Jellyfin FFmpeg Transcode.log (6.6 KB)
N/A
N/A
