Transcoding ans VPN not working
I have a Nothing Phone 3a using TailScale to access my jellyfin server at home at all times, but when i am connected to the server using VPN the app treats the link as mobile and transcodes at a low bitrate that i have set it to even tho i am on WiFi. How do i fix this?
Upload description: FtarSupportVpn
In the screenshots i am cleary on wifi, but the song is getting transcoded even tho i have transcoding off
I cleared the logs, played a song on wifi, then disconnected from wifi to mobile data and skipped to the next song to be played over mobile data, then uploaded the new log
Check the advanced settings. Metered wifi as mobile and VPN as mobile.
Already tried that, both on and off; it’s not the issue, unfortunately. :confused:
Then provide proper logs ? :wink:
Did i not uppload them correctly, i appolagize in that case. The problem seemed to have been fixed tho so thats good, no idea how :confused: .
