When I choose a track or an album to play, the first half-second or so is usually cut off. This also happens when I use the skip forward/skip back buttons on my player, or when I use the progress slider to try to go back to the beginning of the song. It’s important to note that I have fully turned off and disabled ALL fade, mix and crossfade options.
Plex
Open the app on my Fiio M21
Select any album or track
Additionally/alternately: Click the “back” button to start the track over, click the “back” button to go back to a different track, or use the progress slider to try to start the track over.
Seems also the files are strange 2026-04-07 16:02:28.325 Verbose ExoPlayer Mp3Extractor - Data size mismatch between stream (4241784) and Xing frame (4241477), using Xing value. does it happen on all files ?
Thanks for the reply! I have the Hi-Res Support for Local Renderer active, which I understand automatically disables the Skip All Silences option. But I also never activated Skip All Silences, because I only use Symfonium for music.
I’ve tried it with a few different kinds of files: MP3s, ALAC ripped from CD, ALAC converted from FLAC, FLAC, ALAC downloaded from Bandcamp and Qobuz. As far as I can tell, it happens across the board.
There doesn’t seem to be a way to share the Android bug report. When I click on the notification and select the option to share the bug report, it just tells me that “no app can perform this action.”
