Track scan on Jellyfin 12.1 hang after 125000 entries
I tried to launch a sychronisation of the database connected to a newly upgraded jellyfin 12.1.
I as been worked fine and fast until 125000 entries, but after start to be very slow and finally failed at 131000 entries.
Open settings
Go to synchonisation manager
Click Sync
Wait until it failed.
debug.log (This is the debug log linked to the issue I opened regarding sync issue after 125000 entries on jellyfin 12.1 (User Cheeeese))
Thanks for the log. I can reproduce the failure sequence from it: Jellyfin answers the earlier track pages, but the requests become much slower near 126,000 tracks. The page starting at 132,000 never answers before the timeout, even after retries, so Symfonium ends the sync. Your previous library appears to remain intact.
Could you check the Jellyfin server logs around the failed requests and confirm whether the scan was run on the Samsung tablet shown in the debug log? The report lists a phone. That would help distinguish a slow server query from another issue affecting this run.
Hello, I trying to found information on the jellyfin logs, but there is absolutely no entries about the scans. I need to check if I can change the verbosity level actually set to “Information” as minimum level.
It look that the symphonium library as been updated because some new albums are missing,
You’re right the logs I sent you are comming from a Galaxy Tab S11, but I did the same test on a Samsung A57 phone with exactly the same issue on the same track count.
The good news is that jellyfin 12 solve the scan performance issue came with version 11.
I changed the logs level to debug and relaunch a scan, I maybe found some errror linked to the scan. There it is.
Got this error replicated many times
[2026-09-26 15:34:14.618 +02:00] [DBG] Error converting value.
System.FormatException: RunTimeTicks is not a valid value for ItemFields.
—> System.ArgumentException: Requested value ‘RunTimeTicks’ was not found.
at System.Enum.TryParse(Type enumType, ReadOnlySpan`1 value, Boolean ignoreCase, Boolean throwOnFailure, Object& result)
at System.ComponentModel.EnumConverter.ConvertFrom(ITypeDescriptorContext context, CultureInfo culture, Object value)
— End of inner exception stack trace —
at Jellyfin.Api.ModelBinders.CommaDelimitedCollectionModelBinder.GetParsedResult(IReadOnlyList`1 values, Type elementType, TypeConverter converter)
System.FormatException: ProductionYear is not a valid value for ItemFields.
—> System.ArgumentException: Requested value ‘ProductionYear’ was not found.
System.FormatException: CommunityRating is not a valid value for ItemFields.
—> System.ArgumentException: Requested value ‘CommunityRating’ was not found.
Then this one, one time while the scan become very slow.
[2026-09-26 15:31:43.007 +02:00] [WRN] The response has already started, the exception middleware will not be executed.
[2026-09-26 15:31:43.009 +02:00] [ERR] Connection id "“0HNORQ5JMDL26"”, Request id "“0HNORQ5JMDL26:00000003"”: An unhandled exception was thrown by the application.
System.InvalidOperationException: Response Content-Length mismatch: too many bytes written (864923 of 864035).
at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpProtocol.WritePipeAsync(ReadOnlyMemory`1 data, CancellationToken cancellationToken)
at Microsoft.AspNetCore.ResponseCompression.ResponseCompressionBody.WriteAsync(ReadOnlyMemory`1 buffer, CancellationToken cancellationToken)
at Microsoft.AspNetCore.Http.StreamCopyOperationInternal.CopyToAsync(Stream source, Stream destination, Nullable`1 count, Int32 bufferSize, CancellationToken cancel)
at Microsoft.AspNetCore.Internal.FileResultHelper.WriteFileAsync(HttpContext context, Stream fileStream, RangeItemHeaderValue range, Int64 rangeLength)
at Microsoft.AspNetCore.Mvc.Infrastructure.FileResultExecutorBase.WriteFileAsync(HttpContext context, Stream fileStream, RangeItemHeaderValue range, Int64 rangeLength)
at Microsoft.AspNetCore.Mvc.Infrastructure.FileStreamResultExecutor.ExecuteAsync(ActionContext context, FileStreamResult result)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.g__Awaited|30_0[TFilter,TFilterAsync](ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Rethrow(ResultExecutedContextSealed context)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.ResultNext[TFilter,TFilterAsync](State& next, Scope& scope, Object& state, Boolean& isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.g__Awaited|28_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.g__Awaited|25_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Rethrow(ResourceExecutedContextSealed context)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.g__Awaited|20_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.g__Awaited|17_0(ResourceInvoker invoker, Task task, IDisposable scope)
at Jellyfin.Api.Middleware.ServerStartupMessageMiddleware.Invoke(HttpContext httpContext, IServerApplicationHost serverApplicationHost, ILocalizationManager localizationManager)
at Jellyfin.Api.Middleware.WebSocketHandlerMiddleware.Invoke(HttpContext httpContext, IWebSocketManager webSocketManager)
at Jellyfin.Api.Middleware.IPBasedAccessValidationMiddleware.Invoke(HttpContext httpContext, INetworkManager networkManager)
at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)
at Jellyfin.Api.Middleware.QueryStringDecodingMiddleware.Invoke(HttpContext httpContext)
at Swashbuckle.AspNetCore.ReDoc.ReDocMiddleware.Invoke(HttpContext httpContext)
at Swashbuckle.AspNetCore.SwaggerUI.SwaggerUIMiddleware.Invoke(HttpContext httpContext)
at Swashbuckle.AspNetCore.Swagger.SwaggerMiddleware.Invoke(HttpContext httpContext, ISwaggerProvider swaggerProvider)
at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)
at Jellyfin.Api.Middleware.RobotsRedirectionMiddleware.Invoke(HttpContext httpContext)
at Microsoft.AspNetCore.Localization.RequestLocalizationMiddleware.Invoke(HttpContext context)
at Microsoft.AspNetCore.ResponseCompression.ResponseCompressionMiddleware.InvokeCore(HttpContext context)
at Jellyfin.Api.Middleware.ResponseTimeMiddleware.Invoke(HttpContext context, IServerConfigurationManager serverConfigurationManager)
at Jellyfin.Api.Middleware.ExceptionMiddleware.Invoke(HttpContext context)
at Microsoft.AspNetCore.Builder.Extensions.MapMiddleware.InvokeCore(HttpContext context, PathString matchedPath, PathString remainingPath)
at Jellyfin.Api.Middleware.BaseUrlRedirectionMiddleware.Invoke(HttpContext httpContext, IServerConfigurationManager serverConfigurationManager)
at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpProtocol.ProcessRequests[TContext](IHttpApplication`1 application)
And a second time
[2026-09-26 15:43:18.998 +02:00] [WRN] The response has already started, the exception middleware will not be executed.
[2026-09-26 15:43:18.998 +02:00] [ERR] Connection id "“0HNORQ5JMDL29"”, Request id "“0HNORQ5JMDL29:00000003"”: An unhandled exception was thrown by the application.
System.InvalidOperationException: Response Content-Length mismatch: too many bytes written (938387 of 937267).
Then the scan failed without any revelant message.
Tell me if you need the full logs during the scan, I send it.
Just in case it was not clear this is a Jellyfin side issue, the logs are more for them than for me. Don’t paste random text like that.
