Track repeating after continuous play
I use Tracks (sonic analysis based which works fine, but after a while, tracks start to repeat themselves in a loop. If you look at the logs around the time of upload, you will see the issue
Upload description: repeating tracks
Plex
Yep let’s try to find something in 180 000 lines of logs without really knowing what to look for …
What about you tell me actually what tracks repeats at what moment so I do not loose hours ?
example of tracks that repeat
So the logs from yesterday at 20 will have those at 17:20 in it ?
You do realize that seeking needles in haystack is not really an useful usage of my time ?
I need logs and matching actual details of the repeating tracks and view of the queue and all the necessary details to be able to analyze the logs.
I’ll try and repeat and capture a video of the issue. Ta
I need both the logs and the video to match things.
Typically a 1 star rating song can’t be present.
The 1 star was me trouble shooting.
Hello. I have uploaded a new log “repeating tracks1911“ and a video “WhatsApp Video 2025-11-19 at 12.25.23.mp4” via https://share.symfonium.app/
what i have noticed is that repeated tracks are due to “duplicate“ tracks in my library, which you can see in the screen recording. However, I need to understand whether a modification to your code can be made to ignore identical tracks during playback. I know it’s technically not a bug, but as it’s an edge case, it would be very helpful. I suspect other users would experience something similar
  1. Schoolboy Q - Blank Face is part of an album and also a compilation
  2. Davido - Pere is part of multiple compilations
P.S Ignore the one star - it’s me cleaning stuff out
Thoughts?
A different track is a different track, there’s no easy / proper way to handle duplicates that would work for all providers. Just mark the duplicated tracks as Exclude from personal mixes so only one version will be left for those.
