Track not appearing when placed in album directory
Recently tagged an album placed all tracks of said album into a folder & copied that to my SD card.
Track 5 does not appear in symfonium when it is in the folder with all the other tracks from the album which is odd. If I re-copy the file over the app acknowledges that there is a new file, auto sync begins as expected. If that track is in the album folder it just won’t appear in the album, the moment its outside that folder, bam she appears.
Upload description: Peekaboo Track Track 5 (Problem Track): SPIDER-MAN SUPERMAN - PARTYNEXTDOOR (OVO).flac
I’ve simply copied the file to my SD & tried moving said file via android file manager & while plugged into a PC (via windows file explorer)
This track just doesn’t appear in the app when in the album directory, outside of the album director the track plays perfectly normally
EDIT:
In a shocking new development I tried renaming the file to
05. PARTYNEXTDOOR - SPIDER-MAN SUPERMAN.flac
& it appears & plays properly now.
My only logical guess is the file path + filename may be too long??
Have you cleared tag cache ?
Not at first.
I just tried that & re copied the file…no dice
Shortening the filename did work though for now i’ve changed the filename from
to
SPIDER-MAN SUPERMAN - Drake (OVO)
I’m not sure i’m convinced this is solely an issue of filepath length though.
This album is in
SD-CARD/Music/Drake/Some Sexy Songs 4 U by PARTYNEXTDOOR & Drake [E] (2025) (OVO)
But I have a soundtrack in
SD-CARD/Music/Soundtrack 2/METRO BOOMIN PRESENTS SPIDER-MAN ACROSS THE SPIDER-VERSE OST MP by Metro Boomin (2023) (ST2)
And that album doesn’t have this issue at all.
In the logs the the file have the tags extracted.
How do you mean? Or rather how does that happen?
I don’t know, there’s no extraction error and the file have the tags extracted I do not have enough details to get the rest.
I also happen to have symfonium on my PC via subsystem for android. Interestingly the file on my PC has no issues with it being in the same album directory.
On my phone I also have Oto music player installed and that same track was missing from the album when placed in the album directory.
Based on that I’d assume its safe to say something goofy is happening with my Galaxy S9 / External SD Card specifically… I just don’t know what exactly
