Hi, I was wondering if there’s a way to shuffle tracks like in standard music players. I have a huge tracklist and I’ve run into an issue: when you type a track into the search bar, tap on it, and then hit the shuffle button at the bottom, the next tracks that play are only the ones from the search results, not from my whole library.
I saw there’s a ‘smart queue’ feature, but it’s pretty clunky and you have to keep turning it on manually. I just have a massive library and want to listen to a constant variety of tracks. And yeah, I know you can just hit ‘shuffle’ on the main screen, but sometimes I want to listen to one specific track first and then have random tracks play right after it. Thanks in advance!
Upload description: didnt sent logs cuz problem is not local
Instead of using the Search page to find your starting track, you want to use the Tracks page (via Library, the NavBar, Home Page shortcut, etc.).
You can use the text filter (magnifying glass icon) to search this page just like you would on the Search page. Tap the song to play it, and the app should queue all tracks in your library as well.
Now hit the shuffle button in the Now Playing screen, and voila!
Ah, sorry. I didn’t hit play myself, you’re right. That doesn’t work.
You could try the Instant Mix instead of using the Shuffle button. If it’s not already on your Now Playing Screen, you can go to More Actions and press Instant Mix there.
