Too many errors, stopping playback on Kef LS50-2 UPnP
I can select Play on UPnP to the Kef speakers, but when I try to play something, nothing is played and I see the error, “Too many errors, stopping playback”. I also see “Error playing media, make sure your player support it” error on first attempt.
Plex
  1. Open Symfonium
  2. Select cast button and choose the Kef UPnP speakers
  3. Select Play on a piece of music
  4. See “Too many errors” error.
Kef speakers were working quite well on UPnP, but not at all as Chromecast players until a recent update reversed the situation. Music does play to the Kef speakers on UPnP if I set Symfonium to Proxy via Symfonium. Turning off gapless support does not fix the issue.
michael.glasson
Means that there’s a problem for the device to directly talk to your server, or https issues. There’s nothing I can do here the option is here to workaround that and as you see works.
