For whatever reason, some titles show normally some titles showing like this drive me nuts. I don’t need it to be perfect with everything, just show the original file name is fine by me. pls help me how to fix it??
Upload description: joyce2261
Tolriq
July 10, 2025, 6:03pm
2
Your file have 3 different tag formats in them with 2 of them invalid.
Use a proper tag editor to remove the invalid ID3 tags from those files.
I believe you can use mp3tag to delete all the tags, except one.
I had the same issue with a bunch of my files too.
I spent a little time and just have one tag format now. You can decide which format you want.
I tried using mp3tag, and it appears correctly on my PC now. However, Symfornium didn’t update the tag accordingly. Did I miss anything?
Assuming you removed all the tags, but one, your need to resync symfonium.
If it doesn’t look right in symfonium, I can guarantee that it’s on your end, and with your tags.
thank you it helps a lot!
You’re welcome. We all get help along the way!
