Not sure if some of the following have been covered already but I have noticed a couple of things that in my opinion are missing after using the app for a week or so. I hope it helps and thanks for the app.ybe tap artist/album to
Too few songs queued on playlist shuffle.
Shuffle playlist (playlist 700+ songs), view queue and only queued 30 songs. Go back to playlist and then have the option to use Queue button and add the entire playlist into the queue. It is a smart playlist (favorite songs) and there is no set item limit. -
If I have a queue with 700 songs the app should pick up where I left off in the queue. I currently use Musicolet a lot and it does this. I only need to tap play I’m right where I left off, even after days or rebooting the phone. Doing this I’ll eventually get through the entire playlist.
Add “quick action shortcut” option (long tap on app icon) to continue playing, open to playlists, etc.
I use Emby and the time in the Emby dashboard is incorrect…. It shows something like 6:23:22 / 4:44 and doesn’t always scrobble to Last.fm
No easy way to get to artist/album from the Now Playing. Maybe tap artist/album to go there. Not having this makes it more difficult to add songs from the currently playing artist to the queue.
