Tailscale android auto network issue
Plug phone into car with tailscale enabled and songs will not play until I open the app on my phone for something in the network to switch.
I have tailscale automatically turn on when I leave wifi.
Without android auto, I can open the app and it will go though the tailscale DNS and work correctly.
If I just unlock the phone while connected to android auto, symfonium still does not switch to taislcale DNS even though it should be forced.
Once I open the symphonium app, the song trying to play starts right away.
Navidrome
1.Symphonium is closed on phone.
2. Connect to android auto and still connected to wifi. Songs play.
3. Leave wifi area and phone switches to mobile and tailscale. For some reason it uses external DNS to resolve to my home IP instead of my local DNS to resolve to the lan IP.
Started android auto at 6:00 am.
Tailscale with subnet router masquerading turned off and subnetrouting turned on. Allows the tailscale IP to be visible to Reverse proxy instead of the subnet router ip.
Reverse proxy blocks external access except for tailscale IPs. This is why in the log it shows Synology page error.
Local DNS forced on LAN and tailscale.
cremonies
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
