System backup says: "Exceeded backup quota"
When I am making a system backup with Seedvault (on idoéOS) it says
I found this issue in their repo: Is it possible to change the backup quota? · Issue #183 · seedvault-app/seedvault · GitHub clearly stating that the app probably wants to backup data that is just not needed. I suspect that Symfonium adds the cached media to the backup data which is not needed there… Additionally I noticed that the system settings data tab also states that all the cached media is listed under “user data”
Upload description: BentiGorlich
  1. You’ll need an android wide backup in iodéOS that is SeedVault. I think Google has something backed in as well (but I don’t know)
  2. Let Symfonium cache a few media files
  3. Try to do the backup
  4. You should see the quote exceeded warning in the backup status
Symfonium does not add anything anywhere and actually disable OS backups because they are broken.
You can backup Symfonium in the backup and restore section, using other solutions is not supported and will probably not work.
I have other apps installed that “do not allow” backups as described in the backup status, but Symfony does report something else there. Why exactly are you’re saying that they are broken? I just thought I’d try it out :sweat_smile:
Because they will backup config files with non transferable values, database with non transferable values and all of the offline cached media in it.
Symfonium backup / restore system backup exactly what is needed to restore without unneeded or not valid data.
Apologies about bumping this post. I had experienced the same error and I was curious if the android.app.backup API was considered as a potential solution for this.
In particular it mentions using this API can “Perform backup of arbitrary data to remote storage” & “Restore the data saved to remote storage”.
It sounds like it should be possible to make it so Symfonium will disable the android backup from accessing Symfonium files and instead just return the backup data which Symfonium creates itself.
It then should be possible to set everything up based on the backup data on first launch.
I am aware this is probably not a feature too many people would use but I thought I would mention it.
