Synfonium Transcoding When Not Supposed To
Hello,
Been loving the app so far, but I’ve been running into an occasional issue with offline downloads.
When I select an album or artist to download from, it ocassionally transcodes some or all of the files from their original format. I have it set to not download original quality in Synfonium, so I was wondering what the issue might be.
When I delete the file, it continues to redownload as a transcoded mp3 instead of a flac. I’ve found that sometimes I can fix the issue by deleting the media info cache and internal states and fully restarting the app, but I’m not sure how much that’s actually helps fix the issue.
The log should be attached to my username. Thanks for all the work you do on this app!
Upload description: arthuliborsei
Issue occurs both when using WiFi and 5G, and has occured when remote as well as when on the same network as the server
Plex
Your logs are empty and not reproducing the issue.
The most common issue is that you are connected via plex.tv relays at the moment you start download and so are limited to 1 or 2 Mb depending on Plex pass or not. If the FLAC are higher bitrate they are transcoded.
