I am using Navidrome 0.54.4 with Synfonium version 11.6.0. When I look for the album parachutes by coldplay in Navidrome, I can see the full album. But when I try to find the album in Synfonium, I am missing the first and last songs. The only thing that I notice is that both song titles and the filenames have ’ in them and am not sure if that is the issue.
2025-01-26 10:57:18.047 Verbose SubsonicLogger <-- [662] {"subsonic-response":{"status":"failed","version":"1.16.1","type":"navidrome","serverVersion":"0.54.4 (73ccfbd8)","openSubsonic":true,"error":{"code":0,"message":"Internal Server Error: sql: Scan error on column index 4, name \"play_count\": converting driver.Value type string (\"v\") to a int64: invalid syntax"}}}
@deluan got some details about that one? First time I see it.
For the rest the songs are not returned by the API either so also something on Navidrome side.
I think this one is on me. I was modifying the Navidrome SQL database to match my playcounts from iTunes and must have fat fingered the playcount with as ctrl+v command. I fixed the DB and its working. Thanks for the info and quick reply!
