Synced lyrics are not available for songs in rolling cache
I listen to a song with synced lyrics. It’s added to the rolling cache. With no connection to the server, I can play the song but no lyrics are available. Moving it from rolling to permanent cache yields the same result.
Update:
However directly adding the song to the permanent cache when it’s not already cached works as expected with the lyrics available offline.
Upload description: 655321 synced lyrics not cached
The provider is lms, the lyrics are external (.lrc files).
  1. start playback of song with synced lyrics
  2. song is added to rolling cache
  3. turn off connection to server
  4. play song, no lyrics available
This is expected the rolling cache is server agnostic. There’s no solutions for now.
Pity. Having to remove the songs from the rolling cache only to then add them to the permanent cache directly for lyrics to work offline is superflous work imho.
Well is there any other solution on the market that does that better ? :wink:
Are you willing to pay 15 days of work to fully rewrite the lyrics handling ? :wink:
Or you can add the lyrics in the tags and have it working right now :wink:
