Sync with pCloud does not work automatically, scans all tags
My music in pCloud does not sync automatically, I have to do it manually after adding new music. Everytime I do the manual sync, it scans the tags of all of the existing files instead of just the new ones, so it takes quite a while to finish.
Upload description: debug-20251116_093744.zip
Upload new files to pCloud server.
Synfonium will not automatically sync the library.
Manually sync pCloud to the library.
All music files in the server will be scanned and the new files will show up in the library.
pCloud
Yes sync is manual as the docs says, no the app does extract cached tags, but needs to check all folders for changes, and to finish you should update the app on your device.
Hi,
I assumed the option for automatic sync was there, since there is a button to “disable auto sync” in the settings?
I also found this post referring to automatic sync, so I’m a little confused.
thank you! I’ve updated the app and will report again if the problem persists.
