When switching the wifi network the sync aborts (tested with jellyfin and lms).
Upload description: 655321 wifi switch aborts sync
The log this time includes me manually switching the wifi while jellyfin syncs (takes less than 10 seconds). lms behaves exactly the same. If you need logs for the aborted lms sync as well, just let me know.
- Start the sync
- manually switch wifi or walk out of range of a network and into range of another network
- sync aborts
Any provider
