Symfonium Volume Bug with DAC using USB Exclusive mode
I’m currently experiencing an issue with my DAC when using the USB Exclusive Mode. When I play music and lock my device, the volume gets reduced a lot when pausing and resuming audio playback. I have to manually increase it when this happens. This happens around 75% of the time.
This seems to be happening since the last update. The first implementation of the USB Exclusive Mode did not have this issue.
I hope this issue can be resolved soon. If more data or testing is necessary, I can help if wanted.
  1. Play a song from the library.
  2. Lock the device.
  3. Open the lockscreen.
  4. Stop playback.
  5. Start playback again.
I use a Galaxy A54 Phone with OneUI 8.5 Android 16 as OS. My DAC is a Fiio KA15.
SHirsch Volume Change USB Exclusive Mode
Thank you for the logs. I can see the volume drop on resume: Symfonium reads Android’s media volume as 9/15 and applies it to the KA15, changing its USB volume from 100 to 60. The DAC confirms that change, which explains the large drop.
I still need to establish why Android’s volume became lower. During the pause/resume sequence where this happened, did you touch the phone or DAC volume controls, or only the lock-screen pause/play buttons?
You can also enable the option Disable USB exclusive volume safety in playback / Advanced settings as a test.
Hi Tolriq,
I only touched the the lockscreen play/pause controls. I did not touch the DAC or Phone volume controls.
I also tried the mentioned setting, but it did not fix the issue.
Provide new logs starting from the DAC unplugged to plug and reproducing this.
I currently have troubles reproducing the issue on my end. It works flawlessly right now.
