Symfonium needs a WiFi connection to initially connect to server
When on mobile data, Symfonium doesn’t connect to my Navidrome server.
(I also have Dsub2000 on my phone, and it connects to the same server via mobile data.)
When I connect to any WiFi network, I can see all the music on the server, and once I start playing an album/playlist/artist I can disconnect the WiFi and Symfonium continues using the mobile data.
Navidrome
(only connected mobile data)
Open symfonium
Search for an artist
  • “no results”
    Turn on WiFi
  • the results field is full of the expected tracks.
    Select the artist.
    Select Play.
    Disconnect the WiFi, and playback continues.
Shared log with support - with my username of gairsty around 10:00 BST
You have enabled filters, probably auto offline mode too.
I have “Automatic offline caching of favorites” enabled to permanent cache.
What filters have I enabled?
Only you can see all your screen settings :wink:
You have either only available offline or related global filter on, or the automatic offline setting.
“Automatic offline mode” - that’s the setting. I’ve turned that off, and all is well again in the world.
Thank you.
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
