I have a playlist of 1179 tracks, while inspecting the debug.log it properly read all the 1179 .opus tracks but for some reason after a query builder event it returned 1178 tracks.
Upload description: azuriye log with playlist file.
Place the playlist file into a folder which Symfonium scans and once recognised inside the Files sub-menu simply import the playlist and wait until it appears in the Playlists sub-menu with a toast notification indicating the process has finished.
Hello, that seemed to fix the issue. Looks like foobar2k exported playlists as UTF-8 BOM .m3u8 files. Probably why the hashtag was appended by foobar2k but I always removed it thinking it wouldn’t pose an issue.
