Symfonium ignores the "ignore explicit tags" setting
Settings > Manage Media Providers > 3 Dots > Edit > Ignore Explicit Tags
Enabling this and pressing on “Update” button, then closing settings and going back in to see the same setting reveals that it had been reset to it’s default disabled state.
i have after pressing update, also “synced” to register the change, nothing changed,
Upload description: jayse aliciakeys
Thanks will fix, triple click the subsonic logo at the top and press save to have it working for now.
You still need to do a sync after to be applied to the data.
Oh wow it has been fixed despite it supposedly being temporary, how did it work despite no update being pushed? what did the triple click the subsonic logo at the top do?
It use a different path that does not check server state, that path properly save the option.
