Phone: Nothing Phone 2 (Android 15)
subsonic - Navidrome server
Have been using symfonium from a long time but recently noticed that it is heating the phone.
I usually connect a charger and was always confused whether any app was causing the heat issue or it might be due to charging.
Went through the forums and also cleared the internal state and cache as well on 28th May 2025.
So I put the phone on charger and started listening to songs on substreamer and after 4-5 songs touched my phone and it was normal.
Then I started symfonium and after 4-5 songs touched the phone screen and it was warm again.
I tried going through logs and couldn’t find anything. Any suggestion will be helpful as I am now addicted to symfonium and other players just can’t cure the itch now.
Upload description: raul824
Play songs in symfonium and after 4-5 songs touch the phone screen and it will be warm than usual
Force stop symfonium and play songs in either browser or substreamer and touch the phone screen after 4 or 5 songs.
