Symfonium do not see DLNA renderer, other apps works
I’m trying to play music on DLNA Renderer (foobar2000 in this case, ip address 192.168.100.4). Symfonium sees other rendereres in network (Chromecast), but not my DLNA target. BubbleUPNP sees the target. Tried proxying foobar to OpenHome renderer, Symfonium still don’t see it, BubbleUPNP does. In the past I streamed from Symphonium on this phone to Xbox One, which I believe is DLNA, so it should work? Sent debug logs as “Tepiloxtl no dlna”
Upload description: Tepiloxtl no dlna
  1. Run foobar2000 and foo_upnp plugin on PC. Make sure to allow foobar200 throug Windows firewall
  2. Open Syfonium, open cast dialog
  3. Observe foobar2000 DLNA renrerer not showing up
  4. Open BubbleUPNP, open cast dialog
  5. Observe foobar2000 DLNA renderer appearing there
What is the IP of that device ?
Also provide bubble upnp logs please.
I have updated my first post with ip, its 192.168.100.4. I have uploaded bubbleupnp logs to share.symfonium.app, but it didn’t ask me to name the upload? sorry, the filename is com.bubblesoft.android.bubbleupnp_log.txt if that helps
In the logs foobar does not answer to anything dlna related and Bubble seems to use OpenHome stuff to connect. That’s not UPnP and not supported in Symfonium.
I found the issue, likely foobars upnp plugin fault. It only shows up as renderer in Symfonium if I open foobar while on the cast screen in symfonium, same in bubbleupnp, but the openhome proxy was hiding this issue
I have uploaded this scenario as “Tepiloxtl foobar cast” just now, from force shutdown application, open application, open cast screen, then restart foobar on PC
I guess they do not answer to the search query and only send the broadcast on start and every X minutes or so and so not during the discovery phase.
Not much I can do here.
