Symfonium cannot connect to navidrome. Unclear what is going on. Would great if I could see symfonium logs myself, then I wouldn’t need to involve support.
Navidrome logs;
May 4 04:41:44 navidrome navidrome[56169]: time=“2026-05-04T04:41:44Z” level=debug msg=“HTTP: GET http://music.dablyputs.lan:4533/music/rest/ping.view?u=dsewell&p=[REDACTED]&v=1.13.0&c=Symfonium&f=json” elapsedTime=“31.671µs” httpStatus=302 remoteAddr=“192.168.50.68:36988” requestId=navidrome/bGAHCAYdM1-002844 responseSize=28 userAgent=“Symfonium/14.1.0 (Linux;Android 16)”
May 4 04:41:44 navidrome navidrome[56169]: time=“2026-05-04T04:41:44Z” level=debug msg=“HTTP: GET http://music.dablyputs.lan:4533/app/” elapsedTime=1.9ms httpStatus=200 remoteAddr=“192.168.50.68:36988” requestId=navidrome/bGAHCAYdM1-002845 responseSize=2678 userAgent=“Symfonium/14.1.0 (Linux;Android 16)”
Caused by: java.net.ConnectException: failed to connect to music.dablyputs.lan/192.168.50.15 (port 4553) from /192.168.50.68 (port 54434) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
at libcore.io.IoBridge.isConnected(IoBridge.java:347)
at libcore.io.IoBridge.connectErrno(IoBridge.java:237)
at libcore.io.IoBridge.connect(IoBridge.java:179)
at java.net.PlainSocketImpl.socketConnect(PlainSocketImpl.java:142)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:390)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:230)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:212)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:436)
at java.net.Socket.connect(Socket.java:646)
at c37.e(r8-map-id-7d5028efcc9a19e053e10e329a7141f8e68840adc91cef2b3ca50491f7852513:1)
at im1.i(r8-map-id-7d5028efcc9a19e053e10e329a7141f8e68840adc91cef2b3ca50491f7852513:70)
... 6 more
